Root Issues with katana rom
t12b25
Hi everybody I'm running katana rom 11-16 build. Anytime I get a call I have no sound, even when trying to select ring tones there's no sound. Any ideas?. I need help. Thank you for your help.
Anthony.
Good job.
On the sd card, copy contents on it to a pc using a usb cable and then wipe the sd card in twrp. Then reboot your phone all the way. Go to playstore d/l sdfix app and gametheorys recovery rebooter. Reboot all the way again then Reboot to recovery, do a backup to your externel sdcard and when done, restore your saved data you want from your pc.
Cheers, merry xmas
