Hi, first time poster and recent Android convert - can't find an answer to this problem anywhere, so hopefully someone here will be able to help me out.
I'm trying to work out if it's possible to play music from the iTunes Library on my PC through my Android. I know there are a couple of apps (like AirBubble) that might do that, but the problem is that I have to use the Hotspot function on the Android to connect my PC to the internet so the two devices aren't both on some third network, which is what apps like AirBubble need.
Is is possible to get the Android to connect to the Wifi network that it itself creates through Hotspot? Or if not is there some other way of dealing with this?
Thanks
Ryan
Thanks
Ryan
