I've got a problem (Open Home 2 + widgets)
elon
I installed some widgets and they worked very fine in the original home, yesterday I installed Open Home 2 and when I'm tap&hold the screen and select widget I can't see any of the widget that I installed....
What can I do to see them.....?!!?!?!?
thanks for all the people that help :D
(and I'm sorry if I wasn't supposed to post it here....)
That's odd. OpenHome supports widgets, so they should show up in the same place. Did you try switching back to your normal home screen and trying them again? Can you still add them that way?
On the normal home and in another apps that I have (91PandaHome) I can add them..
but I couldn't see them in openhome...
