Java and SQL
brentc
I get no compiler error. The execution does not return from the following method...It crashes.
public boolean deleteOne(CustomerModel customerModel) {
SQLiteDatabase db = this.getWritableDatabase();
String queryString = "DELETE FROM CUSTOMER_TABLE" + " WHERE " + COLUMN_ID + "=" + customerModel.getId();
Cursor cursor = db.rawQuery(queryString, null);
if (cursor.moveToFirst()) {
return true;
} else {
return false;
If I implement a Toast like this....
Toast.maketext(MainActivity.this, "Hello", Toast.LENGTH_LONG).show();
It flags MainActivity.this with the error "is not an enclosing class". What should I use for that?
