Jorte Calendar Problem - Recurring Monthly Event will NOT Delete on Phone
scudder
Android Expert
I'm having a Jorte problem...forgive me if this was discussed already but the situations I read in the forums seems to be a bit different...
I can create a recurring monthly event in Jorte or online in my Google Calendar for, e.g., the 29th of every month starting on March 29, and the calendar item shows up fine online and in Jorte.
But HERE is the problem...
When I try to delete the recurring even while USING JORTE I CANNOT. I have been unsuccessful attempting to delete TWO DIFFERENT ways...
First, if I hit the event and click "Delete" I am asked "Do You want to delete this event?" I click "Delete" and NOTHING happens. STILL there...
Secondly, if I try a different way...click the event, hit "EDIT" instead of "Delete" and then choose to edit "Change this and all future events" or "Change all events in the series" and choose "Delete" again, ALL OF A SUDDEN the "Repeat" information changes from "29th of every month" to "Custom...(cannot customize on phone)
It AIN'T custom...it is NOT "every other 3rd Tuesday on even months" or something like that...it is a SIMPLE RECURRING EVENT...
And it is DEFINITELY a JORTE PROBLEM because I can ANNOYING go to the stock calendar app and delete that event "and all future events" if I choose WITHOUT A PROBLEM!!
Any thoughts?? Anyone else having this problem??:confused:
