scudder
Android Expert
Hi...
Been using Jorte for a long time but realized a little issue with trashed emails.
Seems that they are staying in the "trashed" folder. I would like to delete them TOTALLY but the only way I can seem to do that is to MANUALLY choose the "Empty Trash" option (by long pressing a folder or viewing the folder and clicking "Menu"...there are various ways to get to the "Empty Trash" option) and then "checking mail."
Is there a setting to have the trash emptied AUTOMATICALLY?? I know that many, if not all apps, have a "safety" feature built in to the app so that you don't TOTALLY delete something you might have trashed by accident. But there are also options to empty the trash after a certain amount of time or days or something. Anything like that in Jorte??
THANKS!!
THANKS!!
