RobertRiter
Everytime I use Juicedefender's "disable data" widget to try to put my phone in standby mode (this would be entirely fine with me most of the time, given the only time I want data is when I actually want to use it, and I figured this could be a battery lifesaver), it works fine.
Totally kills the data.
The problem is when I try to turn it back on, it simply will not come back online. It might show the 1x or even 4G logo, but nothing that uses data can access the phone. The only option to fix it is to completely turn off JuiceDefender and restart the phone with the power button.
Has anyone had any luck getting JuiceDefender's data disabling features working without totally crashing the data without a reboot?
