Jvc 55 inch.. firmware problems
You don't state if your TV is working or not so I'll assume yes and that maybe the update has just hung or crashed.
The normal go to option would be to perform a full factory reset of the TV to restore it to the original state and then start applying the firmware updates.
Although it should be noted there maybe an issue with this TV and a certain firmware that may brick the TV upon reset!
If I search your TV model number the first item that comes up is this:
https://www.diyforums.net/i-have-a-...d-a-factory-reset-and-now-it-w...-155850.html
Ah, still under warranty? Sounds like this could be the only option judging by the post I linked. :thinking: Did you try any of the reset options in the link?
You could out of interest try the flashlight test..
Grab a flashlight and make your room as dark as you can, switch the TV on and shine the flashlight across the screen to see if you can see any movement. If you do it's a hardware failure and you definitely need a repair.
