k-9 email help
boatman
Wierd, did a search for K9 , and found nothing, can't believe it....
Anyway, wondering if anyone else is having this problem.
At certain times, using k-9, I can't open attachments. For instance, someone sent me some pictures as a jpg. I can see a thumbnail as the attachment. When I try to open it, I get a message 'No application can peform this action'. Then there is acheck box for 'use default for this action'. Checking that brings up dialog 'clear default in Home settings>applications>manage applications. Going there has nothing in default.
Same thing for pdfs. Normally they open. Today I tried one, says ' quickoffice: file cannot be opened'.
I can usually fix this by re booting the phone, but tried that 2x, and did not help. I can't get direct help from K9 guys.
Thanks
