Keeping sound picker on during other tasks
Rgarner
Android Expert
I recently acquired a Samsung A02s. Sound picker works ok, including with a Sony Bluetooth speaker. However, if I try to do something else while the music's on, it stops. Is there a way to fix this? If I have to download some other app to get it done I probably will but I would prefer to keep it simple.
If whatever else you are doing has audio, then whatever is in the foreground will likely have dibbs on the audio.
You may be able to turn off the audio for certain apps, like games, so that you can listen to what you want while doing stuff.
