Help Keyboard issue
kle17011
LG G2 VS980 Android 5.0.2
Two issues:
1. I no longer have a comma on the keyboard, instead I have two (.) periods. I want the comma back.
2. Many times when I type a message, the keyboard letter does not appear but the symbol on the kay appears. Example - I type the letter T, but the symbol % appears.
Not problems as serious as others, but nuisances just the same.
Not sure if you are using the stock keyboard, but since you didn't mention any I'll assume that you are. No idea what is going on there, but I can tell you that lots of users here like Swiftkey and the Google Keyboard so you might want to give those a try. They are both free, as well as Touchpal which I am currently using and highly recommend also.
Thank you for the suggestions. Downloaded the Google keyboard and am giving it a try.
