Hello people.
I do use BottomSheetDialog and there are some Edittext etc...
But the problem is that when the keyboard pops up, not the whole
BottomSheet is over the Keyboard.
I've tried:
d.getWindow().setSoftInputMode(WindowManager.LayoutParams.SOFT_INPUT_ADJUST_RESIZE);
and any SOFT_INPUT parameter. Nothing is changing ._.
MainActivity
Main Activity.xml
content_bottomsheet_new_pocket_item.xml
I've tried:
MainActivity
Java:
final BottomSheetDialog d = new BottomSheetDialog(this);
Objects.requireNonNull(d.getWindow()).setSoftInputMode(WindowManager.LayoutParams.SOFT_INPUT_ADJUST_RESIZE);
d.setContentView(R.layout.content_bottomsheet_new_pocket_item);
d.getBehavior().setHideable(true);
d.getWindow().setSoftInputMode(WindowManager.LayoutParams.SOFT_INPUT_STATE_HIDDEN);
button2.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
d.show();
Main Activity.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<androidx.coordinatorlayout.widget.CoordinatorLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:id="@+id/coordinatorLayoutPocketMain"
android:layout_height="match_parent"
android:fitsSystemWindows="false"
tools:context=".PocketMain">
<com.google.android.material.appbar.AppBarLayout
android:id="@+id/app_bar"
android:layout_height="@dimen/app_bar_height"
android:fitsSystemWindows="true"
android:theme="@style/AppTheme.AppBarOverlay">
<com.google.android.material.appbar.CollapsingToolbarLayout
android:id="@+id/toolbar_layout"
app:contentScrim="?attr/colorPrimary"
app:layout_scrollFlags="scroll|exitUntilCollapsed|snap"
app:toolbarId="@+id/toolbar">
<androidx.appcompat.widget.Toolbar
android:id="@+id/toolbar"
android:layout_height="?attr/actionBarSize"
android:layout_marginTop="22dp"
app:layout_collapseMode="pin"
app:popupTheme="@style/AppTheme.PopupOverlay" />
<androidx.constraintlayout.widget.ConstraintLayout
android:layout_height="75dp"
android:layout_gravity="bottom">
<Button
android:id="@+id/button2"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_marginStart="8dp"
android:layout_marginTop="8dp"
android:layout_marginEnd="8dp"
android:layout_marginBottom="8dp"
android:text="Button"
app:layout_constraintBottom_toBottomOf="parent"
app:layout_constraintEnd_toEndOf="parent"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintTop_toTopOf="parent" />
</androidx.constraintlayout.widget.ConstraintLayout>
</com.google.android.material.appbar.CollapsingToolbarLayout>
</com.google.android.material.appbar.AppBarLayout>
<include layout="@layout/content_pocket_main" />
</androidx.coordinatorlayout.widget.CoordinatorLayout>
Code:
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:background="@color/colorPrimary">
<Button
android:id="@+id/button"
android:layout_marginTop="32dp"
<EditText
android:id="@+id/editText"
android:layout_marginBottom="60dp"
android:ems="10"
android:inputType="textPersonName"
android:text="Name"
app:layout_constraintTop_toBottomOf="@+id/button" />
<EditText
android:id="@+id/editText2"
android:ems="10"
android:text="Name"
app:layout_constraintStart_toStartOf="parent" />
