Can you give more information? What is your device? What is the OS? Is it stock or rooted? When did it start to be a problem? Did you install something that triggered the problem? Perhaps you could describe what the problem is?
It's a galaxy s4. started when I downloaded an app to control the phone while driving. The problum is that I changed the keyboard settings and now in the Google search it shows gibberish in the search lines. I have no idea what I actually did =/
Did you change to another language? Can you revert back to what you want and try rebooting? If that doesn't work uninstall the app you downloaded and reboot. Failing that wipe your cache partition:-
Turn off phone
Remove the battery and reinsert.
Hold down the Home and Volume Up keys
Press and hold the Power button while still holding the other keys.
As soon as you see the Samsung logo, release all keys/buttons.
Press on the Volume Down to scroll down to Wipe Cache Partition.
Press the Power button to select it.
Press the Volume down button to highlight "Yes" and press the Power Button to select it.
Wait for a few minutes for the phone to clear the data.
Then press the Power button to select reboot system now.
Wait for your phone to reboot.
I'm Pretty sure that it has somthing to do with the voice control settings. I did tried to change to another language, but I can't find it now. And I'm too scared to wipe cache partition, what exactly it will do?
