Help Keyboard won't work occasionally.
Motorhomer
I have a weird problem that's only just manifested itself on my OnePlus 6. On one forum of which I'm a member the keyboard displays but hitting the keys does nothing, so I can't type. If however I reboot the phone it will then work, but not for long. I was using the Gboard that came with the phone but I installed SwiftKey and the problem is the same, so it can't relate to GBoard.
Any ideas from the experts out there? Thanks.
Through its website. It's a local newspaper forum and I can access it OK and open up a response to a post. The keyboard appears but does nothing.
If you're not having any issues with other apps or websites, it might be something going on with their end.
Found a few threads at XDA and the OnePlus 6 forum about keyboard issues, but none that completely matches your problem. Hopefully someone else here will see this thread and have better ideas on what to try.
Sorry I couldn't be more helpful.
