A
anas darai
Guest
Today I present to you a wonderful application KgTv player that includes many advantages that are not available in other applications such as the search feature and the popup window and the speed and ease of use and the size is very small: it is also very safe if it is available in the Google Play Store
These are the full application features:
-- Pop-up window for an independent application that allows you to view any channel, And enjoy the same time using other applications such as Facebook and Google Chrome.
--⏰ Super speed when viewing channels and perform other tasks.
-- Quality Change System Allows you to choose the quality of the broadcast as appropriate.
-- The possibility of changing the place of and size player easily and at any time and depending on your taste.
-- Channel search system is easy and fast.
--⚠ detector errors which reveal 90% of the errors, which helps to solve problems.
--✔ Automatic verification system for links provides effort and tiring experience.
-- system tags add to the aesthetic application and it organizes the channel list It supports languages and even qualities.
-- Advanced internal player supports most types of processors.
-- support secure communication via the https protocol.
--➕ Allows you to add channel listings from a link to a file or to a text file .
--✍ Ability to edit ✎ or delete channels easily.
--♻ automatic debugger for the names of the channels.
--⛔ automatic system to remove pornographic channels works by 70%.
-- Automatic system to reconnect to the server when a defect occurs.
-- ️ fully support for Smart TV and Android Box.
-- Support system shortcut links ShorTv.
Enjoy now kgtv player with more than 5000 channels
Code: FL-UX-US
Number of channels: 5000 channels
Duration: Lifetime, with updating for each period
Application link on Google Play
https://play.google.com/store/apps/details?id=tk.kgtv
Pictures from the application:
Code: FL-UX-US
