I have heard that Seidio makes a good kickstand case. Any other contenders?
The metal kickstand with magnetic closure you find on Seidio SURFACE (or Best Buy Platinum - the same re-branded case but cheaper) - is the bar none. Plus SURFACE itself is a very nice slim case, and you can add CONVERT on top of it for extra outdoor protection.I have heard that Seidio makes a good kickstand case. Any other contenders?
