Bootloaders still on locked down and is there a one click bootloaders workaround for noobs my friend was wondering about it he wants to root and install cm or a custom ROM of any for his kfhd7inch
There isnt a one click method as of yet but the process is fairly easy if you follow this http://forum.xda-developers.com/showthread.php?t=2128848 . and Hashcode is fighting with a bug on the CM ROM for the HD 7 . but itll be done soon.
What's the bug and do I download both imgs and what do I use to put the codes the terminal in SDK and a few more questions step 4.5 how would it be done
its a display bug. and yes download both images. and i only know on windows. use CMD. make sure the images are in the same path when you type the path in CMD. as for 4.5. just download the 7.2.3 bootlader and flash it. then continue to step 5 and flash the 7.3.0 bootloader.
