Aditya342
This app is for experimental purposes. I shall not be responsible for any damage caused by this app.
Consider a Full backup before proceeding
This app is tested on most of the models which has label ‘Supported’
This app disables KNOX and changes SELINUX to Permissive.
Author : Aditya Banerjee (Purchased by Venus342)
For best results, follow these :
1) Use SUPERSU for Root Access.
2) Transfer this app as a System App
3) Ensure you have KNOX.
4) Ensure you have Busybox installed in System/bin
A one-click tool to Disable Knox and reset KNOX Counter to 0x0
If it says KNOX not found by mistake, probably your device isn’t supported. Please mail your device specifications.
This app is compatible with most of the devices
What does this app do?
1) Change SELINUX to Permissive
2) Complete enhanced removal of KNOX SDK with total removal of KNOX Components
3)Reset KNOX Counter to 0x0
4) Fix root issues if device has missing or lost root access (Issues will be auto-detected)
WARNING: DON’T USE WITH BLACKLISTED MODELS
Minimum memory required : 2 GB Free Memory Required
GET IT ON GOOGLE PLAY : KNOX RESET
PLEASE NOTE THAT WE HAVE STOPPED PRODUCTION OF KNOX RESET FREE. NO HELP OR TROUBLESHOOTING GUIDE IS AVAILABLE FOR KNOX RESET FREE. GET THE FULLY WORKING PREMIUM VERSION FOR CHEAP RATES NOW.
bit.ly/knoxreset
For free version, mail us at venus342.in@Hotmail.com
bit.ly/knoxreset
