Kodi wont connect to sources
Last night i formatted the flash drive i had in my android box. Now my kodi wont work. Iv reset the whole box reinstalled kodi twice. I can get into kodi but when i add source i add fusion. I go to install from zip and can install the repo but when i go to install from repo and click the repo it says cannot connect to repo. And it only does this with all the fusion repos.
Are you in the UK, Ireland, or other EU country? If so your ISP is blocking the illegal pirate sources, like Fusion, that's why you're seeing "can't connect to repo." It's a common problem with these cheapo Kodi boxes from China, often in the UK with ISPs such as Sky, BT, TalkTalk, Virgin.
