Country_Gravy
Member
So I rooted my phone without any problems but I am having a really hard time getting the RyanZAOLagFix or whatever it is called to work. I can't seem to get the 2.2+ fix to work because it says that the device is out of room. I have offloaded all my apps that can be moved to the sdcard and deleted most of the rest that I hardly use to free up space. The 1.0+ fix says that it can't create a loopback or something.
Is there any lag fix that you guys would recommend or any way I can get this one to work. I would like to get this thing running quickly...I have heard about the quadrant scores of over 2000 and that sounds good to me.
