so i'm on KG6 which is 2.3.4, and everything works fine except when i'm scrolling through the homescreen that is slight lag where the transition becomes choppy and doesn't flow smoothly
I found that program monitor widget was the problem, when i removed it, it works fine. However i don't want to get rid of this widget as I use it all the time
Is there a 2.3.4 version or some alternative which won't create lag
