hi all,
I have a problem like I described shortly in the topic.
When I try to unlock my phone after longer period of not using it, there is a lag during the slide move, it looks like it was happeining not fluently and slowly, and usually, when I get to home screen, after hitting any icon, it takes some time until I see anything. i.e. I hit applications, and all icons appear with a lag, unfluent movement.
But what strange here, and needs to be stressed, that it happens only after longer period of not using the phone. When I unlock phone, get it to work fluently, then lock, and then unlock right after that, I works fine. What may cause the problem? Anyone?
First, I thought it was because of widgetlocker, so I uninstalled it, but no luck.
Then, I cleared all cache, no success neither.
After that, I thought it's because of launcher pro, so I switched to android implemented home screen, but neither any better.
Finally I decided to upgrade to 2.3.6, but it also didn't help me a lot.
Do You have any suggestions what may cause this behaviour?
Thanks
Thanks
