Today I was playing a game on my laptop. The game froze for a few seconds (as it normally does) and I hit the keyboard fairly hard. It was still working fine. I went to restart the computer, and I clicked "force shutdown". It shut down.
Note that I have Windows 7 and Windows 8 CP installed on separate partitions.
When I tried to boot it back up, Windows 7 took an insanely amount of time to get passed the black screen with the Windows logo and text that says "Starting Windows".
Eventually it got to the blue screen with the flower with the loading-circle and "Welcome" text and "Windows 7 Home Premium" text at the bottom. It didn't get past that.
So I rebooted into safe mode, and it got to
"Loaded: \Windows\system32\DRIVERS\CLASSPNP.SYS"
then stopped loading.
Then I booted Windows 8, and it booted normally. I ran some system tools/defrag on the Windows 7 partition and it passed, though it took forever.
So I tried to boot W7 again, and it took multiple times longer to get passed the black screen with the Windows logo sign.
I booted Windows 8 again. It literally took 20 minutes to boot, when it normally takes 30 seconds. Now, W8 is running insanely slow. At the login screen, it took about 15 seconds for the password text box to gain focus so I could type my password. After a grand total of about 40 minutes, W8 is now loaded. So I go to switch to desktop, and it took about a few minutes to switch from metro to desktop.
I don't know what is going on. It's not a virus. I don't think it's a registry error, because it wouldnt effect W8 partition right? Did I damage the hard drive? Is it taking its last few spins as I attempt to load windows? Could I have broken or disconnected my RAM and now everything is loading as Virtual Memory on the hard drive?
Also note that I am able to access files on the W7 partition from the W8 partition.
There is no odd noises coming from the laptop.
I opened Task Manager in W8. It says
0% CPU (jumps between 0-1 idle)
14 % Memory
100% Disk (100%? Is this an issue?)
0% Network
Edit
After further experimenting, I loaded Fire Fox with Task Manager open. Under Performance, I clicked Disc. The "Active Time" jumped to 100% for 4-5 minutes. The CPU stayed between 0-1%. FF finally loaded. I also loaded a video from my W7 partition. Ironically it loaded and is playing fine.
It's obviously a hard drive issue, is there anything I can do about it?
14 % Memory
0% Network
Edit
