Spec-Kie
Alright guys,
Need a little bit of help as i am stuck with whats happening to my machine.
Right it has been dropped to start with. i no not a good this to start with i know but it fell off the settee, Right even since then every thing works on in, Thing is when ya turn it on windows boots up with no problems and will staff on after a while or when you try and load something, It turns off. and i have no clue on why it does this? is it windows? or is it a hardware issue? as in heat and cooling? cheers guys for the help in advance.
