launcher not launching
JoeProcopio
was running launcher and although it was clunky...it was fine...then i went back to check something on the regular home app...and i accidentally hit the default key when opening home...now launcher wont launch...where so I set the default back?
next time if you get this problem go menu>settings>applications>manage applications>
stock home (whichever your phone has)>clear default then when you press home button you will get a choice again
