My problem started yesterday, when I unlock the phone I get this "cloud" effect that basically makes the phone unusable for about 2 seconds while it does its thing....I dont like it and I dont know how to get rid of it? I firth thought it was cool, but the lag time while it goes across is just annoying now. Does anyone know how I can disable that? I am assuming its the LPP that is doing it because I cant think of any other widgets or apps i have installed in the last 2 days.
FIXED!
Weather Widget was causing the problem, uninstall-ed and now all is good.
FIXED!
