Launcher Pro Bug
ClubSteeler
I created a bunch of folders to sort my apps. After rebooting, several of the apps in the folders lost their icons, and simply show the default android icon. However the icon displays correctly on the home page and in the app drawer, but not in the folder.
I can remove it from the folder, and put it back in, and it will show the icon, but after a reboot, the icons are gone again. Also, it's always the same icons that have the issue.
Upon further review: Every single icon that is missing in the folder is an application that has been moved to the SD card.
Maybe it has to do with the fact that the sd card loads after the launcher loaded?
Try restarting LauncherPro...
Menu > Preferences > Restart LauncherPro
I use to experience this, back when I used folders (I now use "Folder Organizer" - MUCH better alternative).
In my case, it happened with apps that I had hidden from my app-drawer that would no longer be hidden after a phone-reboot, and required a LauncherPro restart in order to get everything back in order.
Seconded.
I've had times where absolutely none of my apps show up in the app drawer let alone in folders. Restarting LauncherPro has always fixed things.
