Launcher Pro Help
kollarism
Member
Whenever I use the Google Search widget on launcher pro, the widget gets stuck after I search something. I go back to my home screen, and the widget is stuck at the top of my screen and i cant click in it. I need to hold down where the widget "would be about halfway down the screen" and trash it, and re add it. Any help?
Your not crazy, I saw this once too. Can't recall what I did to resolve. :-( I probably just dumped the search tool until I flashed a ROM update.
Try changing back to default launcher and reset up home screens or reinstall lp.
