C chilliking12 Lurker Sep 19, 2010 #1 how do i remove a app from the home screen without deleating it ? or does that just remove it from home screen?
J jollygoon Member Sep 19, 2010 #2 Just long press on it then drag to the trash icon at the bottom. It won't delete the app just the shortcut.
0 02keilj Well-Known Member Sep 19, 2010 #3 It only deletes the app if you do a long hold over the trash can, so just let it go as soon as it turns red
