Launcher pro problem
webstar1
Hi all and I'm having a big problem with launcher pro on my samsung galaxy S. What happens is that when I long press any shortcut on the dock and click on change shortcut, all it does is launches the thing. For example If I choise settings as my shortcut all it will do do launch settings and when I go back to launcher pro, the shortcut hasn't changed. The only ones u can change to are shortcuts supplied by launcher pro I.e. app drawer and homescreens and so on. PLEASE HELP!!!!!! its drving me nuts!
I think you're doing it wrong.
To add shortcuts go to..
1) Long press icon
2) Change shortcut
3) then go to applications
4) then choose the apps shortcut.
Edit: Dont use the fist set of shortcuts for general apps. Only for stuff like email, drawer, messages. Or, shortcut add-ons like the Folder organizer app.
1) Long press icon
2) Change shortcut
That's the part I went wrong. I didn;'t go to applications. Thx
