LauncherPro and copilot
fausteric
Hello
Anyone using LancherPro (Beta v0.5.1) and Copilot at the same time?
Copilot will startup but when I select an icon inside copilot,
copilot will crash.
Is there any way to exit LancherPro other than de-install it?
Faust
Im using the a rooted G1 with cyanogen 2.1
I'm using ADW and can run CoPilot at the same time.. tried also listening to music while using ADW & CoPilot.. it worked flawlessly! I also did the same with Navigon and iGo MyWay.. once again.. flawless. Catch an upgrade to ADW and run it in system and you will be happy you did. You can change your home screen preferences in SETTINGS if you want to keep hold of LP.
