LED Charge Indicator
Deanski
Member
OK, what's with the LED indicator? When charging, it lights up orange while charging, then blue fully charged. This should be normal.
However, sometimes it never comes on at all! Screen is off, attached to stock wall charger.:confused: Only way to tell is looking at the battery icon when the sceen is up.
My HTC INC always shows the LED the moment I plug it in to the charger.
Anyone else have this problem? Your thoughts?
Deanski
I just noticed for the first time last night that the blue light does not come on when fully charged. It did the first few charges, but it hasn't the last time.
The light is on while charging, just not once it's full.
Would like to see it fixed, but no big deal if not. I'd rather see the Loss of Signal and reception issues addressed.
I noticed if I get a text or something while charging, the light goes off. After replying and turning the screen off once or twice, the light comes back on. :/
I agree, the LOS problem must be addressed ASAP.
But just an annoyance in some regard with this LED going on or not.
After using it today, attached charger, orange LED came up....WTF?
Same duplex outlet used for my HTC Inc so it's not power from the outlet.
Maybe the charger is intermittent or cable? Maybe, but wanted to see how many others have same problem after attaching the charger if the LED comes on orange and when fully charged, blue.
Nice to see from a distance if it's fully charged or not.
Thanks!
Deanski
