Root Led lights...????? Help???
sherri
Android Expert
I am posting here (and any other forum I can think of....) to find out if any ROM for RAZR/Maxx allows led light to blink while screen is ON.
Needed when docked or using full screen.CM and CM based ROMs did this on GB. Can't find anything. I don't want to keep flashing to find this, if it isn't possible. Phone is capable. Native OS isn't.
Any help???
It is up to the ROM to allow this. Full Throttle AOKP does. CM based and AOSP do not.
Only issue I have is that although the ROM settings allow led to blink with screen on, you can't control individual colors. I use Light Flow for this. Works perfectly.
