Left Mouse Keeps Continuously Firing
Grangler
Hi all i have been using bluestacks 4 and have a problem with lhe left mouse constantly firing then you cant move on apps.
I have tried window on top mode/disabling precision mouse/different apps.
On modern combat 4 the fire icon changes red when firing your weapon and constantly stays red like your finger is held down i even changed mouse button to keys and set up that way but still keeps firing.Running windows 10 amd ryzen 1600x nvidia gtx 1070 16gb ram desktop so no touch options
And its driving me nuts if anyone can help thanks mark
TRY another.alternatives or try bkuestack 3. or check if is nott the developer bugs
and try remix OS its very nice incase you are having issue you can run with virtualbox and enjoy it also
thanks for the reply i was using bluestacks 4 as some apps wont run on bluestacks 3 ill have to see wich other emulators works with the apps that i use preferably shadowgun legends asphalt 9.
then try use virtual box and run remix OS is android version is the latest.
most time we are not 100sure devs can fix all the errors in bluestack for computers or pcs thats why we advice running android in virtual box
is more better and easier to remove and play games
Found out the problem if you change the dpi in the emulation settings after configuring the controlls it messes up the controlls so config dpi before the controlls thanks for the help
