LFY 1.95 Smoked and Customed
Status
Not open for further replies.
thaDroidz
I just gotta show off what I've done with these last few versions of LFY...
Using Launcher pro plus I learned I can stretch or expand certain widgets full screen across other smaller widgets while still keeping all fully functional.
I would not be able to have my droid as purty and smooth if it weren't for Team Liquidz hard work and dedication..
1.95
-yellow notification text via Liquid tweaks (now I gotta learn to change needed widgets to yellow)
-Calender widget (expanded) across the D-clock Widget
-Next is Youtube stretched across pandora, music mod and audiomanager
-then weatherbug elite stretch across setcpu and battery watcher (I add weatherbug to system apps and edited it's background BLACK..)
-the 15 dock icons are various shortcuts for folders/email apps/phone/games/etc...
background change on various location setting via tasker these are very few of 50 or so b/w darkgroundz..
This looks pretty cool, I really like the weather in the 3rd pic on the top row posted, I like how each day is the length of the screen but shows the current temp to the left...which weather app is that and how did you go about doing this??
Also, if you dont mind, what are your settings in Launcher Pro Preferences > Homescreen Settings > Homescreen Grid? Do you have Auto-fit Items checked?
Thanks, looks good tho! :)
9x9 rows and autofit...
That's weather bug elite
I opened the .apk and changed widget background. Then added it to system apps. in the smoked theme then reflashed.
Next I am gonna try switching the icons up alittle.
Update the weatherbug..
man I am still pimpin the same look..
It will be 2 months nxt week..
running just as crisp and smooth...
I have made peace and harmony...
I am in no hurry to change...
Status
