Hi,
I have accidentally messed up my userdata partition, can't boot to recovery to format it,
tried to flash stock kdz with lgup but didn't help as it doesn't include the userdata partition in the .kdz
Fastboot is not an option, can't enable unlock boot because can't boot to android.
going to have to use Lgup to flash it, But I need a copy of the stock Userdata partition to get started...
If anyone with the lg m210 aristo can help me, I'll give you a copy of My modded Lgup to dump the partition from your device so I can use it to fix mine.
For helping you get to keep my awsome modded lgup tool which lets you dump firmware and flash individual partitions, and I'll give you all credit for Saveing my a.s.s on this one
Thanks a bunch
Astr4y4L
Thanks a bunch
Astr4y4L
