LG G2 Microphone problem, please help
Ron_Kay
There is probably an answer to this problem somewhere already but I haven't managed to find one that solves it for me so I decided to open a thread here incase someone could help me before I rip my hair off.
The problem is that my voice is completely silent in the opposite end during a phone call but when I turn on speakerphone it works perfectly fine, it also works fine when I use a headset even if it doesn't have an own microphone. So this makes me think it's more of a software than hardware problem as the microphone is obviously working?
One thing that is so weird is that when I plug in a headset without a mic, everything works as it should, then when I pull out the headset it continues to work as it should, not only on speakerphone, even if I end the call and make a new one it still works but after a while the problem is there again.
What I've tried to do to solve the problem:
Factory reset twice
Updated to latest OS
Cleaned the bottom holes
I'm forever grateful to the one who helps me solve this.
I had a similar problem with another phone.
I dunked it in water and then it was fine.....but that was a waterproof phone so im not very helpful here
