Help LG G2 Mini battery (?) Problem
RevengerZ
Hi,
I bought a LG G2 Mini second hand that has been used for about 7 months...sometimes it takes 2-3 hours to get full charge and other times it takes 5-7 hours with the same charger and conection (the charger that came with the device and the wall conection), it doesnt even say that its on a slow charge
It happens sometimes also that the battery gets drained for no reason, leaving it iddle with only wifi and 2g it can las betwin 20 hours and 240 (the last one was only once, generaly what i feel happy to get is 120)
Thanks
Hi
That sounds to me like you have something which sometimes makes lots of use of your data connection/wifi. Maybe you have automatic updates for apps from playstore enabled, or something like that? Go through your apps and check. 5 to 7 hours to charge is not unreasonable if the phone is working hard (in the background with the screen off). You could install Gsam battery monitor and/or Wakelock Detector to find out what is using the battery.
You could check my thoughts by leaving it with data/wifi turned off and see how long it lasts.
Roger
thanks for your anwser, it probably is...today i turned off the wifi and it mad a real difference...i tried some aps to see what was draining my battery and no luck
but that doesnt explain why the battery is not chargin at normal speed (i even turned the phone off)
