marloncruz08mc
I have a question I have lg g5 model F700L then ill buy lg cam plus model CBG700 it is compatible? because when I fix it my mobile showing x whith immage of the module. what I can do to I use my cam pls pls help me
The F700 series is intended for the Korean Market
While they all technically are G5's, they aren't identical or interchangeable.
Versions:
H850 (Europe)
LG G5 Speed H858 (Taiwan)
VS987 (Verizon)
H820 (AT&T)
LS992 (Sprint)
H830 (T-Mobile)
US992 (US Cellular)
LG G5 Dual H860N with dual-SIM card slots
The camera is only compatible with the models listed in bold.![]()
Well, if you notice his emboldened devices that will work with the cam, you will see your Korean variant is not listed. And yes it appears your CBG700 is "useless" for you anyway, sorry to sayhow about korean lg g5what is the compatible cam plus?and you mean my cbg 700 is useless
