LG G6 how to use mobile hotspot
The LG G6 can be used as a mobile hotspot. This allows you to connect other devices to the G6 and use its data connection. It's super easy to set up.
Note: Mobile hotspot requires an eligible data plan.
  1. Go to Settings > Tethering
  2. Toggle the Mobile Hotspot switch
  3. If Wi-Fi is turned on, you will be prompted to turn it off. Select YES
  4. Update the Mobile Hotspot password if needed, then select ENABLE
To configure the mobile hotspot settings:
  1. Select Mobile Hotspot
  2. Select Set up Mobile Hotspot
  3. Edit the Wi-Fi network name, password, and security settings then select SAVE
