maximisxxx2
How to fix my LG ms323 imei. i had hard brick it, then using Ubuntu''Linux" by restoring the aboot.img in the phone partition,which it wasn't displaying the UI on boot.Now the phone can boot normally but take about one minute to fully boot on.then i use "LG Laf Recovery Multitool v1.2" to to restore my back up of my laf.img(in phone)and to restore download mode,then noticing that my my mobile data signal bar had an red x indicating of my service is disabled.my SIM card was still in the phone.I didn't went in the phone and do anything.then on the LG recovery multitool, i use the option to boot into recovery knowing i have CWM flash in the phone,then i choose the option to "wipe data/factory reset"and"wipe cache partition",hopping that will fix the problem of service being disabled.when finishing setting up the phone i still notice that the service is still disable with no bars but a red x next to it.When googling my problem, the perhaps the only way to fix this problem is to using something called Octoplus box which require a card or a box??In other information i notice in my status in option "phone #","IMEI","IMEI SV",and "ICCID" had the word null. how should i fix the problem without this octoplus.
