Help LG Mobile Supporter Tool stuck
I am attempting to update my LG Eve from V10F to V10Q using the LG Mobile Supporter Tool under Windows 7. I have tried installing, uninstalling, reinstalling, etc. the updater, USB drivers, etc. I have tried removing the SD card and battery, turning on/off USB Mass Storage Only and USB Debug mode. The furthest I have gone in the process was with:
- no SD card
- battery in
- USB Mass Storage Only off
- USB Debug mode off
The updating software stops after 40%, saying that there is a problem with the communications between the cell phone and my PC. It says that I should remove the battery, put it back in, and restart. That did not help.
Sometimes I can't even get to the updater. The Supporter Tool sometimes gets stuck at "Checking the connection with the cell phone..."
One thing: my Windows 7 installation is inside a Linux VirtualBox. I do not know if this matters, although I know that it worked with the previous update to V10F before...I will try to find a real windows box later when I have a chance.
Any ideas?
The furthest I have got to is at the analysis step:
Analyzing your cell phone environment...
Checking the model...
Checking the S/W version...
And then it stops at 50%.
After an agonizing day trying to unbrick my phone, I had this problem at the final stages. Signed up just to say thanks to youngd24!
