LG Optimus F3 Theme? :D
Status
Not open for further replies.
Thanks for posting here :) Just downloaded them and I am about to get started. I will start with the simple mod first so that I will know for sure how complicated it will be to get something working on your device. If I were you I would make a backup real quick just in case ;)
backup smashcup. Its pointless to me because we cant get into recovery with button combination so id have to use the unbrick method. B)
Ok I will take a look at it and make sure I didn't mess up on my XML editing. At least we know that my updater-script works ;) That's always a plus. For now you can replace your apk with the one you posted and then reboot your phone and it will fix the FC
Hmm this time I made the correction I needed. I will try something different now and see if it is successful. If you don't mind could you check to see how many characters you are allowed to type in a text message before it stops or turns into a mms?
Okay I am going to try and make it where you can send a sms with over 400 characters and over 200 recipients :D If this works then I will be able to get started on the theme
:D Can you look in your "system/framework" and see if there are any other framework apps in there besides the ones you sent me.
I needed that one too, guess I should have been clear when I asked for the .apk's :D Will you please post it for me? Sorry for the delay in this process
Well looked through every XML file in the "xml" folder and can't seem to find what I need. I am going to try and change the dialer numbers and see if that works
Status
