LG Stylo 2 Plus 7.0 Deodexed/Xposed Working!!!
jhgfrtu
Xposed 7.0/7.1
Original Thread..
https://forum.xda-developers.com/xpo...arm64-t36
LG K550 Stylo 2 Plus Deodexed Stock/Nougat_7.0
K550 T-Mobile Nougat Deodexed update v20B
How to install
Must be on nougat 7.0 version 20b rooted, with an unlocked bootloader and latest TWRP installed
Download (3 )zip files
T-Mobile Deodexed zip
https://www.dropbox.com/s/0vio9cuix6...0b7xx.zip?dl=0
v20B zip
https://www.dropbox.com/s/eei5fwzjj7...sybox.zip?dl=0
Modded Kernel Insecure boot.img v20b
https://www.dropbox.com/s/ggtu630uwt...el20b.zip?dl=0
Reboot into twrp (latest 3.1.1)
Wipe dalvik and cache (only)
Navigate to the folder where the zips are located
Flash T-mobile zip, 20vb zip then modded kernel v20b zip
Reboot and phone will take approximately 1-4 minutes to boot the first time
Give su permissions to apps upon reboot
(Open file explorer and navigate to /system/app and open "adobe reader" folder and tap on the apk and install) app needs manual install
(Open file explorer and navigate to /system/app and open "android tool" folder and tap on the apk and install) app needs manual install
Login to google play and update google play services
Go to settings ,about phone, "Update Center", app updates and update your LG apps (calculator etc...)
To enable init.d
open universal init.d app and hit test then tick the activate button
Reboot!
open root file browser and navigate to /system/etc/init.d and highlight the test.init file and set permissions (click all check marks)
Repeat first step
Reboot!
VIOLA!!! INIT.D ACTIVATED!
Changelog:
Security patch August 2017
New Insecure boot.img version20_b
Google installed
Stability improvements
No force closed issues
Cleaned /system/app folders
Kept all LG apps for a complete LG experience.
Nougat 7.0 Deodexed V_20a
Things to do before.
Make sure you have a backup of your current rom.!!
Download zips.
Make sure device is on Nougat 7.0 bootloader!!
How to install.
Make sure your on stock 7.0 V._20a before flashing via TWRP.
1. Wipe Dalvik/Cache only
2.Install tmaxxxdeodex.zip via twrp
3.Install superusers282.zip
4.Install busybox.zip (if busybox isn't already installed.)
4.a Metro PCS users please flash the MPCS v20a build prop zip. (Thanks to fighersteve43)
5.Optional build.prop.zip and Xposed for Nougat. Thanks to the guys here at xda for making this possible.
6.Reboot system and the phone will reboot twice then take around 2-5 minutes to boot.
7.I've uploaded an Insecure 7.0 boot.img for a more permissive kernel.
Here we go!
Deodexed K550 T-Mobile Nougat 7.0 v_20A.zip (T-Mobile)
https://www.dropbox.com/s/4pop7irf7i...40620.zip?dl=0
MS550 Nougat 7.0v_20a.zip (MetroPCS)
https://www.dropbox.com/s/29yzjdk25r...rtest.zip?dl=0
MetroPCS Only //Build.prop.zip (flash after flashing Deodexed zip)
https://www.dropbox.com/s/pnebedkq24....prop.zip?dl=0
Busybox for 7.0
https://www.dropbox.com/s/tsi26q2cb4...S-ARM.zip?dl=0
SU for 7.0
https://www.dropbox.com/s/2hh4vkbylb...71822.zip?dl=0
Optional
Build.prop K550 Nougat 7.0
https://www.dropbox.com/s/ibwdv4xp0k....prop.zip?dl=0
Xposed 7.0/sdk24 I used to install xposed. (credits to the maker of the zip)
https://www.dropbox.com/s/w6app443fx...ifyOS.zip?dl=0
Xposed apk I used (credits to the maker of this apk)
https://www.dropbox.com/s/bfe8mj15ru...id207.apk?dl=0
To install Gapps please visit OpenGapps
Use at your own risk!
Not responsible for your device.
original thread
https://forum.xda-developers.com/an...exed-stock-t3575123/post71484184#post71484184
Not all modules work and lots of force closing.
People should quote that also before posting a non official rovo release..
Insecure K550/MS550 boot.img update.
1.added adb insecure
2. added init.d
https://www.dropbox.com/s/lkdtgu8nx13wijx/K550_MS550_7.0_Insecure_boot.img?dl=0
Init.d mods
set sdcard and micro sdcard read ahead 8192
set mtu 1500 (data)
set cpu max frequency 1401000 ghz big cores 1094000 ghz little cores
set gpu max frequency 450 mhz
set gpu rendering force on on boot
set SE linux to permissive on boot
https://www.dropbox.com/s/hdzyk4gge8zvnvu/Init.dModsSylo2Plus.zip?dl=0
Any mod you don't like or want simply navigate to /system/etc/init.d and delete any mod file of your choice.
Here's a few modules that are working on our LG Stylo 2 Plus. (Nougat)
Finally Gravitybox is working!!. Now one may center the statusbar clock.
Xposed 7.0/7.1
Original Thread..
How to install
v20B zip
To enable init.d
Reboot!
Repeat first step
Reboot!
Changelog:
Google installed
Download zips.
How to install.
Here we go!
Busybox for 7.0
SU for 7.0
Optional
original thread
Updated to v20b
Original Thread
https://forum.xda-developers.com/android/development/lg-k550-stylo-2-plus-deodexed-stock-t3575123
