LG V10 WOULD NOT POWER ON
shamindra
Since last night i was on my phone, battery was showing 70% then the screen went black. My phone would not comes on. i put it on a charger it would not light up or show any sign of charging. I took the battery out wait a few seconds then reinstall, nothing happen. i even tried press the power and volume down button at the same by nothing happen. Any
Try holding the power button for 20 sec. Strait. Not sure that's going to help at all, but it's something to try as you wait for better suggestions
Given what you've described it sounds like there's an internal hardware issue. If you take your phone in to some repair shop to be checked out hopefully it's a fixable problem.
This probably won't make any difference but you did mention pulling the battery and leaving it out for '... a few seconds'. Maybe try this again but leave it out for 'several' seconds if not minutes. (If the issue is some software-related glitch, the residual traces of power in the phone's internal components will take longer than a few seconds to completely drain away.)
