Folks,
Would like to replace my Note 3 and the V20 looks to be the only possible option. It's not officially available in the UK but you can get import versions. I can't just pop into a shop to ask questions about to so I have three:
1. Is the swipe style text entry option available that's on the Note 3? Where you just swipe across the keys without lifting your fingers from the screen.
2. Do numbers appear on the keypad at the same time as letters as on the Note 3? I hate having to press a button to toggle between letters and numbers!
3. Does anyone know whether you can choose a British English language option? Aussie/NZ might do at a push.
Many thanks!
Many thanks!
I am well aware that LG would then not support the phone if it went wrong. I am also aware that the phones are being shipped form overseas. I had worked out you're in China too!
