Anybody else having this problem? It used to work on the first day I got it, then it stopped working when i was testing it out the next day. Contacted LG, went through the troubleshooting process, including disabling Switch Access, turning off then turning the mini view option back on, restarting the phone, and last option to do a factory reset. I was hesitant at first but then decided that I really wanted this feature, so I went ahead with doing the factory reset. It seemed to work, but then after all apps updated, and after checking back on it after an hour, it stopped working once again. All my apps came from the app store. I dont think one of my apps is causing the problem, but I dont really know. If anyone has the same problem, please let me know how to fix it.
I didn't know it had to be manually enabled. Go to Advanced Settings under Display. It's back but still requires a very quick swipe to trigger.
