I just loaded up my LG V20 with the AOKP android 7.1, I plugged in my USB OTG ( SD micro card installed in this) and it will not even power on at all. I rebooted into TWRP, and it works just fine there, I can read, mount and unmount, no troubles. Booted to system, but no power at all to the adapter plugged into the USB-c / charging port. I loaded a second custom ROM, Desolaton, and it behaved in the same manner as AOKP. I then restored the original V20 OS in TWRP from a backup, , and it sees the drive just fine, so it must have something to do with this phone and how it behaves with custom ROM's. My reader is a couple of years old, but doubt that is an issue since is does work on the original OS. Is there a setting I might be overlooking In Settings to enable this to work? Any ideas as to if it might be a hardware of software issue? Thanks.
