LG V30: How to use mobile hotspot
The V30 can be used as a mobile hotspot if you have an eligible data plan. This allows you to connect other devices to the V30 and use its data connection.
  1. Go to Settings > Tethering
  2. Toggle the Wi-Fi Hotspot switch
  3. Enter a password for the network
  4. Update the Mobile Hotspot password if needed
  5. Select SAVE
To configure the mobile hotspot settings:
  1. Select Wi-Fi Hotspot
  2. Select Set up Wi-Fi Hotspot
  3. Edit the Wi-Fi network name, password, and security settings then select SAVE
