GraysonPeddie
I have an LG V35 smartphone (Android Oreo 8.0). I have configured my smartphone for fingerprint locking with Knock Code.
My knock code is correct when the screen is off. Once i enter the correct knock code, my smartphone unlocks. If I turn the phone off while not letting go of the power button and wait for a couple of seconds and turn the phone back on, I can enter the correct Knock code which then unlocks the phone. I need to access the Lock Screen setting to change to PIN with fingerprint unlock because when I try to enter the correct Knock code, I get a message that Knock code does not match.
I did enter the Knock code about 1.2 seconds per tap, but the settings told me it still does not match! I entered the Knock code while the screen is off and I have entered the Knock code within the 4 quadrants properly and correctly, so where can I go from here? Hard reset?
Thanks,
--Grayson Peddie
Update: I solved my problem by doing a factory reset. It's a lot easier than having to troubleshoot and I got all of my apps installed by Google from a backup. If I can mark my thread as a [WORKAROUND], that would be great. And following the factory reset, the use of PIN for unlocking is more reliable than Knock Code. I found it strange that I can unlock using Knock Code, but if I try to change a security setting, my smartphone told me that Knock Code does not match.
Thanks,
--Grayson Peddie
